Trident z compatibility question
  • Trident z compatibility question
    Will the trident z rgb ram work on a gigabyte ga h110m s2h gsm motherboard I understand it will be downlclocked but will there be compatibility issues the reason I ask is because on the g skill page it's says there no compatible memory for my board
    It will work fine, but may only reach up to DDR4-2133 and the RGB lighting software may not work, so rainbow is your default.
