I have the RipJaws V 2133 16GB (2x8GB) kit model F4-2133C15D-16GVR (or single stick model number F4-2133C15-8GVR) with an AMD Ryzen 1700 CPU on an ASUS Prime B350-Plus motherboard with the current latest BIOS version 0503.
While the board seems to detect the RAM and set the correct timings, I am facing some instability in Windows 10 under stress tests like Prime95 or CPU-z where it randomly hard reboots.
I've tried a whole bunch of experiments like using only 1 stick, changing the timings/voltages around etc but still face this instability.
My question is, is this or will this RAM be compatible eventually via BIOS/microcode updates and has G.Skill tested or is planning to test/validate with the AM4 platform?
Thanks!
Thanks!
