System specs:
OS: Windows 10 X64 (build 10586)
MOBO: ASRock Fatal1ty Z170 Professional Gaming I7
BIOS: P1.60 (latest version)
CPU: 6700K (BX80662I76700K) @ Default 4-4.2GHZ
RAM: Ripjaws V, F4-3600C16D-16GVK, (PC4-28800, 8192MB x 2, CL16-16-16-36 1.35v)
Ram is installed in A2, and B2 slots, also known as slot 2, and 4; These are the Priority 1 slots found in the Dual channel Memory Configuration table for my MOBO.
Both XMP's don't work:
XMP1 = 3600 @ CL16-16-16 1.35V, and
XMP2 = 2700 @ CL15-13-13 1.2V
I tried loading the XMP1 settings, with the speed of 3200MHZ, instead of 3600, but I still get memory errors, and blue screen crashes; so after that I also tried boosting the ram Voltage above 1.35V, but that didn't help; then I tried boosting the VCCSA over 1.3V, and that still didn't stop the memory errors, and the system crashes either.
If anyone has some suggestions please help me, and if anyone else has the same ram, please post all your timings, so I can copy them into my BIOS, I'm pretty sure my BIOS isn't choosing all the right timings.
so now I have reduced to 2829MHZ changed latency to C14-14-14-34, and will continue testing at that speed....
