I am interested in the Trident Z DDR4 3200 kits (2x8GB) and have two questions regarding them:
1) Will you clarify what is meant by this statement in you FAQ section:
“We do not recommend mixing memory kits, regardless of brand or model.”
Does this refer to “mixing” two of the exact same kits together? Meaning, I plan to buy one kit of the 16GB (2x8GB) Trident Z DDR 4 3200 (F4-3200C16D-16GTZ) now, and in the future add a second of the same exact kit for a total of 32GB. Is this not recommended? Is it better to buy a 32GB (4x8GB) kit instead?
And/or, does the FAQ statement refer to mixing completely different kits together- for example if I got the 16GB Trident Z DDR 4 3200 GTZ kit mentioned above and then later added the 16GB “GTZB”3200 kit or 16GB 3000 kits- basically, something other than the exact same spec’d 3200 kit I would originally have?
2) You list a GTZ and GTZB version of the kits I am looking at. I see that the “B” version has slightly higher timings compared to the non-B version (18-18-38 vs 16-16-36). In another post on the forums I see that it is confirmed this is the only difference. Therefore, I assume the GTZ with lower timings is “better,” but I want to make sure I’m not overlooking something or unaware of some benefit the higher timed “B” model provides?
