I'm running the latest bios for this motherboard and have "tweaked" the system agent voltage to where I only get 20 errors in the first minute of testing in memtest86. That setting is 1.240625 V. I enabled ez xmp on motherboard. Manual timings. 1.210 DRAM voltage
Ai Overclock Tuner - xmp
CPU Strap - auto
PLL Selection - Auto
BCLK Frq - 100.0
System_service_exception BSOD
System works fine in dual channel mode.
Tested all the sticks individually for multiple hours with no errors. AIDA64, intel burn test, gaming, all are fine in dual or single channel mode.
What more information would be helpful to get this to work properly.
Thank you,
Tei
CPU Strap - auto
BCLK Frq - 100.0
Thank you,
Tei
