Hello GSkill members,
Yesterday I received my new system, some quick specs:
G.Skill 16GB PC3-19200 RipjawsZ DDR3 SDRAM (2400MHz)
Intel Core i7 3820 (Socket 2011, Boxed)
Asus Rampage IV Formula BF3 (Socket 2011)
After I build the system and started it up everything went fine, but I noticed in the bios that the memory was only running on 1600 MHz instead of the 2400MHz which the memory and motherboard are capable of.
I found that I could manually edit the Target DRAM speed so I put on 2400MHz. After changing that value I wasnt able to get into Windows 7 (64x) anymore because of a blue screen. The only option higher than 1600MHz and works without a blue screen is 1866MHz.
I have checked the voltages already, they are just around 1.65 which is stated on the label. I've also flashed the bios to the newest version without any result.
I hope you guys can help me get the system running stable on 2400Mhz, otherwise it would've been a waste of money to buy memory that's this fast.
I am thanking you in advance.
Mitchell
Edit: -------------------------------------------
Found the XMP setting, turned it on and it booted into windows just fine on 2400MHz. CPU-Z still reports a frequency of 1200MHz though..
Mitchell
