8gb or 16 gb G.skills @ 2133 + MIVEZ = double boot issue
  • 8gb or 16 gb G.skills @ 2133 + MIVEZ = double boot issue
    I have bought 2 pair of these G.skill F3-17000CL9D-8GBXM and these also G.skill F3-17000CL9Q-16GBZH. I also have rmaed once my MIVEZ.
    When trying to run all of these rams @ the rated speed i have the double boot issue.
    Until now, im not having this issue ONLY when i run one pair of these F3-17000CL9D-8GBXM @ jedec/default settings.
    The Double-Boot issue is:
    Only from cold boot, sporadicly (it doesnt happen always). I boot the system, system stucks @ debug code 19 and after some seconds reboots and then system freezes @ windows logo. Im doing a hard reboot and then the system boots in windows without a problem. System and memory is stable(memtest, prime95) during windows.
    They say its "ok you can live with it" but for me its really been a PITA and a PIMP(pain in my pocket) until now...
    Here is more info:
    http://rog.asus.com/forum/showthread...ed-with-MEMORY
    Xigmatek Elysium - ASUS Maximus IV Extreme-Z - I7 2700K - G.SKILL 16gb - Sapphire 5970 @ 900/1300 - Corsair AX 1200w
    CPU EK-Supreme HF nickel plated - GPU EK-FC5970 - Acetal + Nickel with EK-FC5970 RAM Backplate - Nickel Plated - Pumps 2 x Laing DDC-1Plus with EK-DDC Dual TOP V.2 - Radiators ThermoChill PA120.3 + XSPC RX240
    Do you have the latest BIOS?
    Did you increase VCCIO Voltage for full slots?
      Yes, i have the latest bios and my mobo has the vccio and vccsa merged, its one setting vccsa/io. So, im not sure how much i can raise it..
        1.10V-1.15V
          1.10V-1.15V
          Is this the max i could go!!!
          Im now trying @ 1.29v Does this maen ill burn something?
            Maybe, the CPU should not need that much. If too much, it can cause instability too, so you should be careful
