Hi guys,
I have a question for you that I cannot find an answer to anywhere else.
I have the old:
G.Skill RipJaws 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit - with the following spec...
Main board intel
System Desktop
System type DDR3
M/b chipset Intel P55
Cas_latency 9-9-9-24-2N
Capacity 4GB (2GBx2)
Speed DDR3-1600 (PC3 12800)
Test_voltage 1.5 Volts
Type 240-pin DIMM
And I am looking to add an additonal 4GB of the same RAM in time for the release of a few games I am looking to buy, but after Googling it all I can find is:
G.Skill RipJawsX 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit - with the following spec...
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL P67
CAS Latency: 9-9-9-24 2N
Capacity: 4GB (2GBx2)
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.5V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Now the above is the X-Series RAM but the spec is the same for everything except from the M/B chipset, so my question is will the X-series work with my older standard RipJaws RAM?
The reason I ask is because I can find the RAM I have - but its twice the price of the X-Series and I would rather not pay more for the same thing...
Cheers guys!
I have the old:
Main board intel
System Desktop
System type DDR3
Type 240-pin DIMM
Main Board: INTEL
System: DESKTOP
System Type: DDR3
Test Voltage: 1.5V
Type: 240-pin DIMM
Cheers guys!
