P8H67-M EVO w/ F3-12800CL8-4GBXM random freezing
  • P8H67-M EVO w/ F3-12800CL8-4GBXM random freezing
    Model of the motherboard: P8H67-M EVO (rev B3), BIOS version 1850 (latest as of 9/21/2011)
    Model of the memory: F3-12800CL8-4GBXM ( have 2 installed: 1 in slot 2 and another in slot 4 for a total of 8GBytes memory)
    Model of the CPU: Intel Core i7-2600K
    I do not have overclocking enabled
    Issue: Random freezing. this has happened since the day I build the PC and installed windows. the freezing tends to happen more when playing games but i have swapped video cards and it still occurs.
    The doubt I have is that I bought all components at newegg and they had recommended this memory but I do not see it listed on ASUS' qualified vendor list.
    So I just need to know if g.skill or the community has tested it on this board? if it does do I need to modify the timings or anything else?
    part of report from cpuz
    Memory SPD
    DIMM # 1
    SMBus address 0x51
    Memory type DDR3
    Module format UDIMM
    Manufacturer (ID) G.Skill (7F7F7F7FCD000000)
    Size 4096 MBytes
    Max bandwidth PC3-10700 (667 MHz)
    Part number F3-12800CL8-4GBXM
    Number of banks 8
    Nominal Voltage 1.50 Volts
    EPP no
    XMP yes
    XMP revision 1.2
    JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
    JEDEC #1 6.0-6-6-17-23 @ 457 MHz
    JEDEC #2 7.0-7-7-20-27 @ 533 MHz
    JEDEC #3 8.0-8-8-22-31 @ 609 MHz
    JEDEC #4 9.0-9-9-25-34 @ 685 MHz
    XMP profile XMP-1600
    Specification PC3-12800
    Voltage level 1.500 Volts
    Min Cycle time 1.250 ns (800 MHz)
    Min tRP 10.00 ns
    Min tRCD 10.00 ns
    Min tWR 15.00 ns
    Min tRAS 30.00 ns
    Min tRC 42.50 ns
    Min tRFC 162.50 ns
    Min tRTP 7.50 ns
    Min tRRD 6.00 ns
    Command Rate 2T
    XMP timings table CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
    XMP #1 8.0-8-8-24-34-2T @ 800 MHz (1.500 Volts)
    DIMM # 2
    SMBus address 0x53
    Memory type DDR3
    Module format UDIMM
    Size 4096 MBytes
    Number of banks 8
    EPP no
    XMP yes
    XMP revision 1.2
    Min tRP 10.00 ns
    Min tRCD 10.00 ns
    Min tWR 15.00 ns
    Min tRAS 30.00 ns
    Min tRC 42.50 ns
    Min tRFC 162.50 ns
    Min tRTP 7.50 ns
    Min tRRD 6.00 ns
    Command Rate 2T
    DIMM # 1
    SPD registers
    00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
    00 92 10 0B 02 03 19 00 09 03 52 01 08 0C 00 3C 00
    10 69 78 69 30 69 11 20 8C 00 05 3C 3C 00 F0 83 0D
    20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    30 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 01 01
    40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    70 00 00 00 00 00 04 CD 00 00 00 00 00 00 00 F3 DD
    80 46 33 2D 31 32 38 30 30 43 4C 38 2D 34 47 42 58
    90 4D 00 00 00 04 CD 00 00 00 00 00 00 00 00 00 00
    A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    B0 0C 4A 05 12 01 08 00 00 00 2A 0A 50 10 00 50 50
    C0 50 78 10 F0 54 3E 00 14 05 3C 30 11 00 3C 00 00
    D0 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    DIMM # 2
    SPD registers
    Monitoring
    Mainboard Model P8H67-M EVO (0x000002C1 - 0x6750EDF0)
    carv,
    Enable XMP and test one module at a time. The memory should work with just the XMP enabled.
      OK I tried to enable to XMP but under EFI Bios Utility advanced mode>AI Tweaker>AI Overclock tuner there is no XMP option. I only have "auto" (which is where it was) and "Manual" options.
      I read on another forums on ASUS site that XMP is not offered on boards with integrated video cards. Even though i am not using the integrated video card i still do not have the options.
      So i believe I have to set this up manually but am not sure what values i must enable or adjust. Can you please make the recommendations?
      The manual can be found here but you have to go through the Asus site. (sorry i have not figured out another way to get it.)
      http://www.asus.com/Motherboards/Int..._EVO/#download
        Input the settings on the memory.
        DDR3-1600
        8-8-8-24
        1.50V
          DDR3-1600
          8-8-8-24
          1.50V
          ok I tried those but the system would not boot. I would get no video and eventually just had to power cycle and the BIOS would give me a message was not able to over clock and it woudl take me back to the EFI screen.
          The only way I could get it to boot would be to to set AI overclock to auto or manual with ddr3 to 1330 or 1066 but it would not work as 1600. I did not mess with the timings at that point since I had no idea if I should even leave it at ddr3 1066 which is where I have it now with timings to auto. please let me know if this is a good setting to try or if I should change it to something else. Ill test it out in the meantime.
          below is a capture from cpuz
          Thanks for your help!!
          Chipset
          Northbridge Intel Sandy Bridge rev. 09
          Southbridge Intel H67 rev. B3
          Graphic Interface PCI-Express
          PCI-E Link Width x16
          PCI-E Max Link Width x16
          Memory Type DDR3
          Memory Size 8192 MBytes
          Channels Dual
          Memory Frequency 533.8 MHz (1:4)
          CAS# latency (CL) 9.0
          RAS# to CAS# delay (tRCD) 9
          RAS# Precharge (tRP) 9
          Cycle Time (tRAS) 24
          Command Rate (CR) 1T
          MCHBAR I/O Base address 0x0FED10000
          MCHBAR I/O Size 19456
          MCHBAR registers
          Memory SPD
          DIMM # 1
          SMBus address 0x51
          Memory type DDR3
          Module format UDIMM
          Size 4096 MBytes
          Number of banks 8
          EPP no
          XMP yes
          XMP revision 1.2
          Min tRP 10.00 ns
          Min tRCD 10.00 ns
          Min tWR 15.00 ns
          Min tRAS 30.00 ns
          Min tRC 42.50 ns
          Min tRFC 162.50 ns
          Min tRTP 7.50 ns
          Min tRRD 6.00 ns
          Command Rate 2T
          DIMM # 2
          SMBus address 0x53
          Memory type DDR3
          Module format UDIMM
          Size 4096 MBytes
          Number of banks 8
          EPP no
          XMP yes
          XMP revision 1.2
          Min tRP 10.00 ns
          Min tRCD 10.00 ns
          Min tWR 15.00 ns
          Min tRAS 30.00 ns
          Min tRC 42.50 ns
          Min tRFC 162.50 ns
          Min tRTP 7.50 ns
          Min tRRD 6.00 ns
          Command Rate 2T
          Edit:
          Well last night it froze up on me again at 1066 setting so i have just set it to run at 1333MHz 8-8-8-24 with voltage at 1.5 and everything else set to auto. Ill see if that helps.
          Edit:
          It did not help. after booting up at 1333 8-8-8-24 it froze after 15 minutes.
          So I am now awaiting your recommendations as i think I am making it worse.
            Sounds it may just be a problem with the kit. This memory should work with just the XMP Profile. Try one module at a time to see if one performs better, that would give you a definitive answer.
              Sorry I have been out of the country and just got back so am trying your suggestions now.
              There is no XMP profile due to the integrated video on the mainboard (see previous post) I have manually added the changes you recommended and am using only one stick set to
              DDR3-1600
              8-8-8-24
              1.50V
              BUT....
              The system will not even boot.
              When I go to the EFI screen>advanced mode it says "ASUS h67 Series motherboard supports 1066/1333 MHz DRAM only"
              So I set it to 1066 with only one stick of ram
              and under DRAM Timing control I set:
              DRAM CAS# Latency 8
              DRAM RAS# to CAS# Delay 8
              DRAM RAS PRE Time 8
              DRAM RAS# ACT Time 24
              DRAM Command mode Auto (not sure if i should put a specific value here)
              Everything else is set to auto (secondary timings and third timings).
              I have run it for one day so far wihtout issue and i plan to run it for a few more days but this might have been the issue. Does this mean I should send in both sticks of ram for RMA? or are there other tests you need me to run first?
              If it freezes again in the next day or two then ill post back here.
              Thanks!
                Try DDR3-1333 7-7-7-21 1.50V
                This motherboard can not overclock to DDR3-1600, but the lower timings above should be even better.
