Heres my current build
MOBO: GIGABYTE GA-970A-D3
CPU: AMD Phenom II X4 965 Black Edition Deneb 3.4GHz
GPU: SAPPHIRE 100338L Radeon HD 6770 1GB 128-bit
RAM: G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800
HDD: SAMSUNG SpinPoint P Series SP2504C 250GB 7200 RPM 8MB Cache SATA 3.0Gb/s 3.5
PSU: CORSAIR Builder Series CX600 V2 600W
Case: Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
Cooler: COOLER MASTER Hyper 212 Plus RR-B10-212P-G1
http://i.imgur.com/lpQlo.png
I keep getting time outs / lag when using the memory. I have only put 1 stick in to see if its memory or if its my settings. Can anyone recommend the optimal settings?
current settings are
1t2t 2t
cas 10
ras to cas 10
row precharge 10
minimum rase 24
1t2t 2t
cas 10
ras to cas 10
row precharge 10
minimum rase 24
