Question???
I have the 2 @ Sniper F3-12800CL7D-8GBSR and when placed in my ASUS Sabertooth 990FX the DIMM Slot 1&2 read the same timing and the DIMM Slot 3&4 read different timings.
Could this be the RAM or is it the MOBO?
Note: This is in the AI Suite II that comes with the MOBO and the also in CPU-Z. But in CPU-Z it also says PC3-12800H (800 Mhz) for slot 1&2 and PC3-12800 (800 Mhz) for slot 3&4 in the Max Bandwidth section. Note that the H is not present in slot 3&4 like it is in slot 1&2. Yet the Part Number reads the same in all four slots. That is why I am wondering if it is the RAM but I am also not sure if it is the MOBO.
Note: I did go ahead and manually enter my timings but it still shows the same info for the SPD. At least the timming is what I want it to be in the Memory section of CPU-Z.
