Looking for some Info
  • Looking for some Info
    I currently am looking to up my ram.Im using an Asus M4A79XTD EVO mobo with AMD Phenom II X4 955 BE.
    I want to upgrade to 8gb.What im looking for is which Gskill ram would be best for DDR3 1600 CAS7 2x4gb dual channel sticks.
    Thank you for any info.
    F3-12800CL7D-8GBRH
    or
    F3-12800CL7D-8GBXH
      Thank you for the info.
      One more question,What is really the difference between the 2 you suggest?
        One is designed for 1st Gen Intel CPU, the other is designed for 2nd Gen Intel CPU. Both will work for AMD, so whichever is cheaper.
          Oops that info was right in front of me the whole time....
          Thx again for the info.
