EVGA P67 SLI/INT I72600K/G.Skill F3-14900CL9Q-16GBXL(1866)
Just received, installed, and brought up to BIOS adjust my new "kit" of GS F3-14900CL9Q-
16GBXL RAM. Removed my non "kit"/matching 16GB (4x4) of GS Ram which had been running
on a "custom" RAM config on my board, with some settings (the ones I recognize) set and adjusted manually. Set timing specs for new RAM (as directed 9-10- 9-28 w/command at 2
(seems one can't enter an N or T) in Chan. A & B in manual and left all other (absolutely no idea what are or how to adjust - if necessary) possible to adjust specs in auto. F4'd and up it came very nicely. Ran for an hour or so, and I'd thought about the possible "advantages" I was missing by not utilizing the illustrious INTL X.M.P. Profile(s) (What's the difference, #1 or #2??) So - in I go to select and enable the dubious advantage(s) of X.M.P.
Typically, and I should have listened to my single cylinder grey matter(brain) - IT wouldn't
BOOT. Well, IT's obviously running now, very nicely in fact, and with all (after CMOS button
click and restoring all my orig manual settings to MANUAL.
There - anybody else having any disagreements/problems/ et al. with X.M.P. ??
Now for the true crux here - and I'm still a bit embarassed/ashamed to ask (can't find one & I've tried) - Herr Tradesman and Herr G Skill Tech - if you're out there - Can/
May I also purchase, con, or cajole a fine G.Skill CASE BADGE from you people??
Thank you for listening (perhaps "reading")
Der Ack
Der Ack
