F3-12800CL9D-4GBRL + GA-G41MT-S2P = Compatable???
  • F3-12800CL9D-4GBRL + GA-G41MT-S2P = Compatable???
    As the Title suggests, I'd like the Gskill admins/tech to help me to find out if that combo is compatible.
    I've got an old Intel Core2Duo PC that is in need of a slight upgrade. I already have the RAM but unsure if it's compatible with the motherboard.
    I checked the Gigabyte website for compatible ram and only found "F3-12800CL9D-4GBNQ" would be compatible, no other F3-12800 types listed.
    http://download.gigabyte.us/FileList...-g41mt-s2p.pdf
    I don't have the motherboard just as I'm getting the facts before finalising purchases.
    The NQ is a good memory kit, so go with that.
      I know that the NQ is a good set as I currently use it in my best PC. What I'd really like to know is if my F3-12800CL9D-4GBRL set is going to be compatible with the motherboard.
        Yes.
