Just bought the Ripjaws X DDR3-2133mhz kit (F3-17000CL9D-4GBXL).
Although I have an AMD based System, I am hitting an absolute limit of 1866mhz @ cas 9.9.9.24.2T. Any frequency above this will result in BSOD, or no POST. I have tried using the XMP profile of 2000mhz which my board supports, however it will not POST at this frequency. I have reset bios, enabled XMP of 2000mhz, with stock timings and 1.6v with no luck. Also have the latest BIOS.
I'm not unhappy with the resulting performance, just wondering if you have any suggestions to pull it even higher? Or have I hit the absolute limit with my processor?
Thanks G.Skill, any help would be appreciated!
PhenomII X4 925 (2.8ghz) OC to 3.5ghz
M4A89GTD Pro/USB3
M4A89GTD Pro/USB3
