im getting a Gigabyte 990FXA-UD3 when they hit stores where i live and i own F3-12800CL9D-4GBRL (2x2gb) im wondering if anyone knows if there will be compatibility issues or whatever? cause it would suck that i'd need to get set for it to work with the 990FX chipset.
i know my ram worked on my M4N75TD tho before the ram slot started to malfunction and fried itself to non working order tho i think one stick went bad in the proccess but won't know till i get the 990FXA-UD3 and see if it did go bad.
Thanks,
G.Skill user
Junko
Thanks,
G.Skill user
Junko
