Hi i bought that pack of DDR3 a while ago i already asked for help here but instead of sending the settings for my motherboard you send me settings to another one so i dont need to say that i cant put the mems at 2000mhz i have a intel i7 920 C0 stepping an asus rampage GENE II bios revision 1501 a Corsair CMPSU-1000HXEU Modular and that set of mems of course i want to put the mems at 2000mhz as i already refered any help would be appreciate thanks.
Problem with F3-16000CL9T-6GBTD
They are similar settings, basically the same. You need to use it as a guide to input the correct settings, then tweak the QPI/DRAM Core Voltage. That is the most difficult part because we can not help you. You need to trial and error test to see what voltage is best and stable.
