Can I use Ripjaws X Series DDR3 1600 F3-12800CL7D-4GBXM with the Gigabyte GA-H67MA-UD2H motherboard? The X series is supposed to be a good choice for the Sandy Bridge processors and chipsets, but they only mention the P67, not the H67.
The Gigabyte site lists F3-12800CL7D-4GBECO on the approved RAM list, but not the F3-12800CL7D-4GBXM.
If the answer is, yes I can use the F3-12800CL7D-4GBXM, is it a good choice for this motherboard, or is there a better choice?
Are there any special settings in the bios I need to make?
Thank you!
Thank you!
