New build with ASRock GX890 Extreme4 and above memory. Periodic crashes. Ran MenTest 4.1 one full pass on 8GB, no errors. System crashes/locks up sometime shortly after boot, other time it?s good for about 3-10 days. Powered off each night. No desire to over clock, just looking for a stable system. Using Windows 7 x64. Motherboard BIOS defaults memory to 1.65V ? should this be more or less? Default memory timing, from SPD is 9 9 9 24 33 2T. CPU-Z pictures below. Please help. Does this memory need to be replaced? Should I follow the sticky in the forum to bring the settings up to 1600? Is this running at 1333 with the current settings? I can change BIOS settings, but I am not familiar with the inter action of the various settings, especially with regard to memory.
Advice on where to start would be appreciated.
I have several CPU-Z images, but not able to insert them here?
