Hello everybody,
First let me thank you all for the forum, I found many useful information here.
And now, I would ask a little help. I'm having a compatibility problem that is driving me crazy, here are the specs of the components:
HexaCore AMD Phenom II X6 Black Edition 1090T
2 x 2GB G.skill F3-12800CL8D-4GBTD DDR3-1600 CL 8-8-8-24 1.6v
Asus M4A87TD/USB3 - http://www.asus.com/product.aspx?p_id=nlwyri9wlniyhaaa
ATI Radeon HD 5830 (Cypress)
The problem happens only with more than one stick, the computer turns on but stays on a black screen, sometimes he passes it, but when you reach the windows always get a bsod with several different messages.
I tested each RAM memory with memtest individually, each stick for 8 hours, none showed any problems, but with 3 or 2 sticks of memory I had many errors in memtest.
I do not know if it makes any difference, but I can not use the first slot for memory because the processor heatsink is on top.
I've tried resetting the BIOS settings and update the BIOS, but did not solve the problem, the BIOS shows the memory as 9-9-9-24 instead of 8-8-8-24.
Does anyone know what might be happening? what else can I test?
