After upgrading my RAM from 4 gb to 8gb with ripjaws ,DDR3 1600 PC3 4096mb x 2, my Cyberpower pc with ASUS AMD Athlon 11x4 640 processor, M4N68T-M-V2 mobo will power up but nothing on the monitor.I put back in the old Ram and it was okay.Reinstalled the ram 2 more times to make sure that was the problem.I went to newegg.com where i bought the Ram and was givin a headsup on this site.I looked at the AMD "sticky" on this here but i don't understand everything about changing the BIOS settings, DRAM freq, and "overclocking".I didn't want to return the Ram and give it a bad review if it was something i could fix.I did check out my Bio's and it is the current version 0501 from 8-3-10.I tried to go to ASUS.com and check the QVL(Qualified vendors list) before i bought the RAM but never found it.Anybody with advice on trying to get this ram to work or return it?.
Thank you guys that take the time to help out newbies.Your greatly appreciated.
jesse
Cyberpower GUA103SE
Consair TX750w PSU upgraded from 450w
ATI Radeon Hawk 5770 upgraded from 5450
ASUS M4N68T-V2 Mobo
AMD Athlon IIx4 640
4 GB PC3 ddr3 RAM kingston upgraded to ripjaws 8g(4gbx2) ddr3 1600 (hopefully)
jesse
Cyberpower GUA103SE
ASUS M4N68T-V2 Mobo
AMD Athlon IIx4 640
