F3-12800CL8D-4GBRM running on Gigabyte GA-P67A-UD4 Motherboard
  • F3-12800CL8D-4GBRM running on Gigabyte GA-P67A-UD4 Motherboard
    Hi, I have just purchased a F3-12800CL8D-4GBRM because all of the Ripjaws X were sold out.
    I tried the XMP setting and the computer seems to restart and run it back to 1333mhz. There was a warning about overlocking and voltage.
    Is this ram compatible with the GA-P67A-UD4 motherboard?
    What are the settings, so I can run this ram at 1600mhz?
    Thank you.
    The settings are on the memory. Instead of XMP, try manually inputting them.
    DDR3-1333
    8-8-8-24
    1.60V
    Don't forget to hit the CLRTC button (Clear CMOS) then input the settings.
