Sorry for the long post, but I figured I'd get all the info out the first time.
I've searched the forms and looked at every post about the config of this motherboard and ram type but I'm still having problems and just need to know if I'm missing anything obvious.
First I'll start with my set up.
ASUS M4A78T-E
F3-12800CL9D-4GBNQ 8gig (4 sticks)
AMD 955BE
Thermaltake Toughpower 750W
Radeon HD5870
I just got the two extra sticks of F3-12800CL9D-4GBNQ as an upgrade and installed them running my previous BIOS settings as follows.
DRAM: DDR3-1600
CPU BUS: 200
DRAM Timings: 9-9-9-24
DRAM Voltage: 1.60
This setup worked stable for my first two stick so I figured it would jive with my new ones. The results were a mixed bag of BSOD and not posting at all so I came back and browsed the post and found some tips and set it up as follows:
DRAM: DDR3-1333
CPU BUS: 240
DRAM Voltage: 1.50
CPU-NB: 1.2000
This only made things worse, so I went back in and reset everything to default (AUTO) and the system indeed ran stable (albeit slower than it should with 8gigs of 1600) but slower than it did with my original 4gig alone.
I started to suspect a bad stick so I went back and did a round of MEMTEST with each stick in different slots and my BIOS set to default. Everything checked out OK with no errors. At this point I went back in and set up BIOS with the above settings and ran all the sticks thru again. Every stick performed good until the last stick was tried and my machine refused to post.
Again, I set everything back to default and all ran well.
Am I missing some crucial setting that is messing up my ram? I only changed the settings listed above I have not changed any of the advanced settings and I have the most current version of BIOS for my MOBO.
Any ideas what I'm doing wrong, or do you think I have some bad ram?
ASUS M4A78T-E
AMD 955BE
Radeon HD5870
DRAM: DDR3-1600
CPU BUS: 200
DRAM Voltage: 1.60
DRAM: DDR3-1333
CPU BUS: 240
DRAM Voltage: 1.50
CPU-NB: 1.2000
