Ga-870-ud3/f3-10666cl7d-4gbrh
  • Ga-870-ud3/f3-10666cl7d-4gbrh
    Model of the motherboard: GA-870-UD3 Bios 5a
    Model of the memory: F3-10666CL7D-4GBRH
    Model of the CPU: AMD Phenom II X4 945
    I want to optimize the system without overclocking or going borderline. Stability over Performance. Usually I only use Intel systems so I am slightly confused that the AMD bios doesn't read the XMP timings and uses slightly different names. So I changed some fields to XMP like values which runs fine in a short memtest session:
    CAS# latency 9T => 7T
    RAS to CAS R/W Delay 9T => 7T
    Row Precharge Time 9T => 7T
    Minimum RAS Active Time 24T => 23T
    Row Cycle Time 33T => 31T
    1T/2T Command Timing 2T
    Are these fields the relevant ones?
    Does it make sense changing the other fields too? To which values?
    What are the "official" good CL7-timings?
    The SPD timings:
    CAS# latency 9T
    TwTr Command Delay 5T
    Trfc0 for DIMM1 110ns
    Trfc2 for DIMM2 90ns (socket empty)
    Trfc1 for DIMM3 110ns
    Trfc3 for DIMM4 90ns (socket empty)
    Write Recovery Time 10T
    Precharge Time 5T
    Row Cycle Time 33T
    RAS to RAS Delay 4T
    Bank Interleaving Enabled
    Channel Interleave Enabled
    thanks for your time!
    The settings you used should be fine, as long as the system is stable.
      Thanks for the answer.
      Does it make sense to change other values than the "big six", the ones mention in the first block?
      Or should they be left alone?
        Well you can manually set them and test for the lowest stable values, but the performance boost would be negligible, so unless you're snowed in somewhere and have nothing better to do, I would say it's not worth it.
          You guys are great and the reason I never felt sorrow for using RipJaw-Memory!
