F3-12800CL9D-4GBNQ Problems
  • F3-12800CL9D-4GBNQ Problems
    Hi there,
    I have a problem in which I get blue screen's in Windows 7 64 bit randomly. I have spent a lot of time reading this forum and have tested out many timings with no luck. One interesting point is that each stick of RAM will run perfectly by itself. I have had each individual stick run stable for weeks or more.
    Model of the motherboard: ASUS M4A785TD-V EVO (http://www.newegg.com/Product/Produc...82E16813131398)
    Model of the memory: F3-12800CL9D-4GBNQ (http://www.newegg.com/Product/Produc...82E16820231193)
    Model of the CPU: AMD Phenom II x4 955 Black
    Thanks for any help!
    Make sure you set DDR3-1600, 9-9-9-24 1.50V.
    Then the last thing to stabilize it is CPU-NB Voltage +0.1V (1.20V).
    Once this is complete, everything should be stable.
