BSOD with F3-12800CL9D (4x2gb) and Asus Sabertooth 55i
  • BSOD with F3-12800CL9D (4x2gb) and Asus Sabertooth 55i
    standard windows mem test checks out fine, but the enhanced flags an unspecified problem and doesn't make it to events log. BSOD happens frequently, so I suspect it is a timing/voltage issue that the MB is assigning as default.
    What timeings/voltage should I use?
    Ram: F3-12800CL9D (4x2gb)
    CPU: 760 i5
    MB: Asus sabertooth 55i
    Thanks!
    Easy method:
    Enable XMP.
    Advanced method:
    Or set AI Overclock Tuner to Manual. CPU BCLK 160. DRAM Frequency DDR3-1600, DRAM Timings tCL 9 - tRCD 9 - tRP 9 - tRAS 24, DRAM Voltage 1.50V. Once this is complete, everything should be fine.
    Obviously XMP is much easier.
      Thanks. I will try that when I get home :-D
      Is there any advantage to manual entry vs XMP for this specific application?
        Sometimes XMP sets some things weird. It depends on how the BIOS likes the memory, but most of the time it is optimal. This particular memory should work well with this motherboard's XMP.
          I used XMP wich also gave the same timings you recommended in manual. I still have troubles. I did the windows memory diagnostic and this turned up:
          - System
          - Provider
          [ Name] Microsoft-Windows-MemoryDiagnostics-Results
          [ Guid] {5F92BC59-248F-4111-86A9-E393E12C6139}
          EventID 1102
          Version 0
          Level 2
          Task 0
          Opcode 0
          Keywords 0x8000000000000000
          - TimeCreated
          [ SystemTime] 2010-11-09T04:32:15.513051000Z
          EventRecordID 9218
          Correlation
          - Execution
          [ ProcessID] 3396
          [ ThreadID] 3400
          Channel System
          Computer Bob-PC
          - Security
          [ UserID] S-1-5-18
          - UserData
          - Results
          LaunchType Manual
          CompletionType Fail
          MemorySize 8181
          TestType 12
          TestDuration 228
          TestCount 6
          NumPagesTested 2093483
          NumPagesUnTested 1123
          NumBadPages 45
          T1NumBadPages 15
          T2NumBadPages 15
          T3NumBadPages 12
          T4NumBadPages 0
          T5NumBadPages 7
          T6NumBadPages 15
          T7NumBadPages 0
          T8NumBadPages 0
          T9NumBadPages 0
          T10NumBadPages 0
          T11NumBadPages 0
          T12NumBadPages 0
          T13NumBadPages 0
          T14NumBadPages 0
          T15NumBadPages 0
          T16NumBadPages 0
          - System
          - Provider
          EventID 1202
          Version 0
          Level 2
          Task 0
          Opcode 0
          - TimeCreated
          EventRecordID 9219
          Correlation
          - Execution
          [ ProcessID] 3396
          [ ThreadID] 3400
          Channel System
          Computer Bob-PC
          - Security
          [ UserID] S-1-5-18
          - UserData
          - Results
          CompletionType Fail
            What slot do you have it installed in? Test each individually to insure neither are defective.
              I have four 2gb sticks installed (every slot occupied). I'll test individually to see if the problem is isolate to a single unit.
              Thanks.
                I think I found the problem stick.
                All pass the basic test
                All pass in pairs. When 4 sticks are installed, there is failure. Shows failure at beginning and test won't complete
                All but one pass the extended test. Test and won't complete
                Been running with 3x2gb so far and seems fine. I think there is just one bad stick.
                  http://www.gskill.com/rma.php
