Just installed these Flares modules (2 x 4GB) in a new build with an ASUS Crosshair Formula M/B. However, I'm unable to hit DDR2000 trying several different BIOS settings.
The rig passed prime95 for 14 hrs perfectly at DDR3-1866 MHz 9-9-9-24-1T with all BIOS settings on <auto> except for using the [D.O.C.P] to configure DRAM freq/timings while setting DRAM voltage to 1.5500. However, when I up DOCP to DDR3-2000 MHz, several cores fail within seconds of starting prime95.
I've tried different combinations of NB voltages from auto (1.11v) to 1.2v and DRAM voltages up to 1.67v, which is where auto settings want to put it, but everything fails immediately.
Hardware is currently in a open test stand (stock CPU cooler) running prime95 @ DDR3-1866 with the following parameters as measured by PC Probe II:
Any suggestions on where to go from here?
Thanks... Brian
ASUS CFIV Formula
AMD Phenom II X6 1055T
Corsair H-50
G.SKILL Flare Series (2 x 4GB)
XFX HD-6870
OCZ Agility 2 60GB
WD Cavier Black 6.0GB 1TB
CM Storm Scout
Vcore 1.26v
CPU/NB 1.16v
CPU VDDA 2.51v
DRAM 1.56v
HT 1.21v
NB 1.12v
SB 1.11v
CPU 51 degC
MB 32 degC
NB 45 degC
SB 41 degC
CPU/NB 1.16v
CPU VDDA 2.51v
DRAM 1.56v
HT 1.21v
NB 1.12v
SB 1.11v
CPU 51 degC
MB 32 degC
NB 45 degC
SB 41 degC
Thanks... Brian
ASUS CFIV Formula
Corsair H-50
XFX HD-6870
OCZ Agility 2 60GB
CM Storm Scout
