asus rampage 3 xtreme with F3-16000CL9T
  • asus rampage 3 xtreme with F3-16000CL9T
    my pc build :
    asus rampage 3 extreme
    intel i7 980x
    2x12gb G.Skill F3-16000CL9T-12GBTDD 12GB (3x4GB) PC16000 DDR3 (2000mhz)
    1200w power by LG
    i want to know how to make safe and good performance on g.skill f3 now i have g.skills f3 in bios default on 1330mhz on lateci defalut 9-9-9-24 1.65V
    what can i do to work on full or beter latenci i want to know if it is posibel to work on 2000mhz and not broke
    coller on rams is new OCZ its faster
    her is the picture how pc looks:
    http://www.shrani.si/f/3z/P3/U07Dsof/dsci0026.jpg
    Enable XMP, check to see what QPI/DRAM Core Voltage is automatically set at, then find the precise QPI/DRAM Voltage your CPU needs. If 24GB does not boot with with AUTO QPI/DRAM Core Voltage, you may want to try 12GB first. Finding this voltage is where most people have problems. Especially if you are attempting full slots, 24GB, it will take some time to trial and error.
      ok 12gb works but 1*12 gb i am still w8 from shop. it works on 1330mhz we can make this 3*4 gb on beter latency now EXP enabled. It looks like this on cpuid*64
        F3-16000cl9t
        I tallk with the store and they and i just want to know for F3-16000CL9T when will this rams be in eu again. They had only one 1*12kit in store and we are w8 for this rams now a 1month . My english is not wery good for that sorry.
        exibo
          Tell them to contact their sales person for accurate information.
            24bg ram
            Hy today I got another 12GB ram so now I have a problem detected by Windows for 24GB of ram. I have windows 7 64bit and as you can see I have lit Mon pic of EXP, ram .... What can I do to be worked 24GB and greater frequency?
                Enable XMP Profile in BIOS, under Ai Overclock Tuner.
                Also, it is best to set the QPI/DRAM Core Voltage.
                  EXP-on
                  I did okay in the BIOS I put XMP ON now on how to now give the frequency as seen in the picture below this is the current situation solely on XMP shoulder currently does not detect properly. On the extent to which the proposed rate it would work?.
                    Core Voltage.
                    Na koliko naj dam voltage da bo delovalo dobro?
                      apologies for this one I just typed and wrote adopted.
                        re2
                        apologies for this one I just typed and wrote his own.
                          what now
                          you can see here http://www.youtube.com/watch?v=5AOylHaCyUA
                          he make manual i pick X.E.P. AND you can see the last picturs with E.X.P. on? what now??
                          For QPI/DRAM Core Voltage dont know how? what is good.?? suggestions?
                          Best regards,
                          exibo
                            You need to test QPI Voltage to see what is best for your CPU. Try 1.20V, then work your way up until it is stable. Once you find the precise voltage, your system should be fine.
                              Bios
                              ok where exactly is it listed in the BIOS under the Extreme Tweaker? where the QPI Voltage is example: QPI / DRAM ram voltage?? is this it
