i've got following System:
M4A87TD Usb3 Board
GSKILL F3-10666cl7d-4gbrh 1333MHZ Ram
Athlon Phenom II 955 BE
Geforce GTS 250
2 SATA Harddrives and 1 SATA DVD Drive
1 IDE DVD Drive
I got various BSOD with the Auto-Settings (Bios Version: 1005)
Ai Overlock Tuner..................Auto
CPU Ratio..............................Auto
DRAM Frequency....................Auto(1333)
CPU/NB Frequency.................Auto
HT Link Speed.......................Auto
Timing Configuration
CAS# Latency.......................9
RAS# to CAS# Delay.............9
RAS# PRE Time....................9
RAS# ACT Time....................24
READ to PRE Time.................5
Row Cycle Time....................33
Write Recovery Time.............10
RASH# to RAS# Delay...........4
READ to WRITE Delay.............8
WRITE to READ Delay(DD)......2
WRITE to READ Delay(SD)......5
WRITE to WRITE Timing.........4
READ to READ Timing.............4
REF Cycle TIme.....................110
Refresh Rate.........................7.8
Command Rate......................1T
CPU and NB Voltage Mode........Offset
CPU Offset Voltage..................1.295
CPU/NB Offset Voltage.............1.100
DRAM Voltage.........................Auto
HT Voltage..............................Auto
NB Voltage..............................Auto
CPU Load-Line Calibration........Auto
CPU/NB Load-Line Calibration...Auto
CPU Spread Spectrum.............Auto
PCIE Spread Spectrum............Auto
Can some one help me to find the right settings? Thanks a lot.
M4A87TD Usb3 Board
Geforce GTS 250
1 IDE DVD Drive
