I have currently obtained a new PC components, including F3-16000CL9D-4GBRH, Gigabyte GA-P55-UD6 and Core i7-875K. I want the memory to run at it's specified 2000Mhz.
Correct BIOS settings for F3-16000CL9D-4GBRH
Enabling XMP profile set memory frequency to 2000 but system is not stable. I haven't changed anything in BIOS, all was set to Auto. I have looked at my BIOS settings and QPI/VTT voltage is 1.2v. I am noob at tweaking BIOS settings and please give me an advice how much I need to increase QPI/VTT voltage? Is there any danger of damaging PC components?
Best regards, 2000.
Well, I tried the folowing manual settings: XMP disabled, BCLK set to 167, CPU Multiplier set to 20, Memory multiplier was set to 12, Vcore voltage set to 1.275v, QPI/VTT voltage - 1.5v, DRAM Voltage - 1.66v, timings were set manually too - 9-9-9-28-2T, tRC set to 47 and tRFC set to 88. Still no luck.
Yet I have set the highest possible voltages that I considered to be safe.
My PC just passed IntelBurn Test! The test was run 5 times at the maximum stress level. I will run another stress tester overnight.
Here are settings:
XMP disabled
BCLK - 167
Memory multiplier - 12
CPU multiplier - 20
CPU Vcore voltage - Auto
QPI/VTT voltage 1.34v
DRAM voltage - 1.64v (I didn't find 1.65v option in BIOS)
Timings were manually set - 9-9-9-27-1T
Any suggestions? Are these fine settings?Last edited by 2000; 10-14-2010, 02:57 AM.
Yes! See what I mean? As long as you spend the time to find the proper voltage, once you find it your system will be completely stable. So now if you overclock, you know what the QPI wants at DDR3-2200+ The idea is to at least find a base, then you can scale your way up.
Enjoy!
Today I have just again checked my system running DDR3-2000 under severe stability test and it failed.
The highest fully stable RAM frequency I was able to reach was DDR3-1900 with timings manually set 9-9-9-24-1T. BCLK 160, QPI/VTT voltage 1.3v and DRAM voltage 1.64v.
I have stressed the system Under IntelBurn Test several times and it seems fine.
Any suggestions how to reach fully stable DDR3-2000?
