I was making my own HTPC and have recently completed putting together the following components:
Intel Core i3-530 with stock cooler.
Gigabyte GA-H55-USB3 [rev 1.0, Firmware F7, mini-ATX form factor]
Sapphire Radeon HD5570 (Low Profile)
G.SKILL F3-10666CL9D-8GBRL 8GB RAM (2 sticks of 4GB each).
OCZ-Vertex2 60GB
Antec ISK 300-150 mini-ITX case with 150W internal power supply.
Now the entire system is set up and works fine IF I use only single RAM stick (4gb).
The moment I put both (in any order, not specific to location on board or the specific mem stick), the motherboard will not boot.
It only keeps starting up, and restarting after about 10 seconds. No message on screen or sound from motherboard.
I tried setting DRAM voltage to 1.6 and some increments above it and also raised QPI/VTT a couple of increments from default(auto) values and it didnt help.
What should I do now ? Any step that I'm missing.
Note: 1. this mobo only has 2 memory slots. 2. Both memory sticks work if used alone.
OCZ-Vertex2 60GB
