Hello Folks,
I would appreciate it if you'd look over my shoulder here and make sure these settings are fine...
My memory is: F3-10666CL8D-4GBECO
First though, I wanted to mention...I have about a dozen set of stix from G. Skill and each pair have performed flawlessly for me over the last 5 years. I wanted to thank you...
Now, onto my questions...
I have two very specific questions.
1) One of my motherboards that I planned on using this memory in, doesn't seem to support the XMP, nor can I adjust the voltage from 1.5v. The memory and the pc in general is very stable. I've run memtest for 24 hours without fault. The motherboard is an Intel DH55TC with a core i3-530.
The question is...is it safe to run this memory at 1.5v?
2) After playing around with it, I found it also runs very stable in Cas7...and the pc feels a bit more responsive. Is this safe?
Here are some screenshots of my pc with CPU-Z for your perusal. Tell me if I'm ok here, or if I need to adjust some settings? I also ran memtest overnight with Cas7...no errors, but I don't want to do any long term damage to my memory.
Thank you for your time and a great product.
Liquid Cool
Liquid Cool
