Gskill F3-16000CL9T-6GBRH compatibility
  • Gskill F3-16000CL9T-6GBRH compatibility
    hi,
    i'm currently building a corei7 + x58 + gskill system ( as my current system went down)
    im looking to buy gskill for their superior speed and performance but im little bit confused whether it will be fully compatible with the system
    hardware
    core i7 950
    evga x58 sli ( only sli not the classified one )
    i will overclock the processor to ~4ghz.
    so is the Gskill F3-16000CL9T-6GBRH going to work smoothly with it ?
    or it will make some kind of problem ?
    4ghz processor and 2000mhz ram will work fine na ?
    thanks
    No problem at all, search the internet, many people love it.
      re
      ok i have decided to buy F3-16000CL9T-6GBTD (2Gx3) .
      but i wanna run 'em on 1600 mhz ( as it doesnt really deffer in speak of performance ) instead of 2000mhz to achieve tighter timings.
      how much lower timing can i expect ? ( by stock its 9-9-9-24-2N )
      thanks.
        7-7-7-21 is no problem, you can then try lower. The lowest should be 6-7-6-18.
          timing
          thanks
          can u give me full details ( timing + settings ) for this modules @ 1600mhz
          my setup is
          core i7 950 @ stock
          gigabyte GA-EX58A-UD7
          Gskill F3-16000CL9T-6GBTD
          thanks
            In MIT (MB Intelligent Tweaker):
            System Memory Multiplier - 12
            CAS Latency Time - 7
            tRCD - 7
            tRP - 7
            tRAS - 21
            Enter these for the other three as well.
            Channel A Timing Settings
            Advanced Timings
            Command Rate - 2
            DRAM Voltage - 1.600V
            Rest to AUTO
              volt
              isnt it suppose to run @ 1.65 v ?
                what volt
                what voltage should i put ? 1.65 or 1.6 ?
                thanks
                  Whatever it is on the memory. Some are 1.60V, some are 1.65V
                    My Trident kit (Gskill F3-16000CL9T-6GBTD rated at 1.60V) can't run @ 6-7-6-21.
                    I tried almost everything but always got a lot of Memtest errors.
                    Is my kit faulty? Is this a valid motivation for RMA?
                    UPDATE: Errors even @ 7-7-7-21 (1.60V)
                      set command rate to 2N
                        Try raising tRFC to 80.
                        tRTP 7
                        You can also see if 1.65V is stable, in case 1.60V is slightly not enough.
                        Keep us posted on the results.
                          This is the result... (1.66V in bios)
                            tRTP is showing 9, also, have you tried 2T?
                              Regarding tRTP I set 7 in BIOS but CPU-Tweaker shows 9.
                              Yes I also tried 2T.
