I bought a setup from newegg. It was a DIY combo, but newegg had an Asus m4a77lt-m le motherboard (95watt max) combo'd with an AMD Phenom II x6 125W 1055T cpu. Also in the combo was this ram:
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-4GBRL
Now, I found out about the 95W and 125W issue once I had already received, and put together the combo kit. So I informed Asus first, then once the guy told me that basically I didn't want that particular motherboard, and if I kept running the 125W cpu in the 95W motherboard that I would eventually burn it up, I proceeded to look into another motherboard. Also with the purchase of a new motherboard was the need for a stronger PSU, because the ThermalMaster PSU that was in the combo wouldn't be sufficient to power any stronger of a board than it was already with. So I purchased this, together..
A 500W CoolerMaster PSU, and an AsRock M3A770DE motherboard.
When I received the new AsRock motherboard and new PSU, i put in the new parts, placed the CPU and all back into the case..and proceeded to start it up. The PSU was DOA, and something inside the PSU caused it to burn out my CPU. So I then had to RMA the dead stuff, which at the time I wasn't sure exactly what was burned up because I couldn't test it...so i had Newegg send me all new parts. New ram, new PSU, new motherboard, new everything...
I then decided to buy a different PSU in the middle of the RMA process because I read too many negative reviews on the CoolerMaster. I also found out that the CoolerMaster only had 360 Continuous watts. So i bought an Antec 620 (Cont)...and finally got all my parts back in, new and ready to assemble.
Assembled and the final build was this:
AsRock M3A770DE motherboard (125W)
Antec ECO v2.3 620W Continuous PSU
XFX 4650 HD pci-e 2.0 x16 video card
Seagate 1TB sata 3.0g HDD
and TWO sets, for a total of EIGHT GIGS, not just the 2x2gb that came in the combo of this:
So i got an 8gb total on DDR3, all of the same kind 2GB ddr3 1333 F3-10666CL9D
My memory timings are manually set in the bios to this:
9-9-9-24 and command rate at 1T
I'm wondering if the guy on another site is correct when he's telling me that my ram or system won't function properly since it's not on the list of supported types.
I'm pretty new to setting bioses and don't know much about how to maneuver it well, so if someone answers, please try to be as technical and directive as possible so I can try to interpret what is being said. I'll do my best to look for what's said but I'm totally a new person to doing this sort of thing.
I've not done any prime95 tests or tried to push the limits of the system, but i'm not seeing any glitches in normal, everyday usage.
thoughts, opinions? Possible settings for this 8gb setup instead of the 9-9-9-24 @ 1T?
And ideas on if I should change voltage or leave it alone.
