I have 2x2gb 4gbrl's xp asus785td v-evoPhenom 2x6 thuban and a vaporx hd 5770. I get several errors logon request even tho I don't have a password setup bsod page faults ect. When I run 2 sticks in dual mode. My system runs 100% fine when only one stick is installed. Is this acompatability issue with my mobo or do i need to change my settings. I need to try something before sending them back.
Bsod ddr3 on v-evo
ddr3
I can operate my system with only one stick of the gbrl ram. If I have 2 sticks placed in eaither single channel or dual channel my system is unstable will not run crahs or doesn't boot. I take out one of the two sticks it goes back to normal. So 2 2gb sticks = instability.
either stick installed 2gb alone the system is ok. I have the asus 2102 bios. I have setting set to factory default the ram is running at 667.
in reference
This article is full of people with different asus boards and g.skill products experincing similar problems. I set my timing to 888 24 1.5v as instructed by an gskill tech and still I have boot issues and after 15 minutes with windows loaded I got non paged fault errors and no reboot. Went back to one sticck and everything is fine. I am going to rma this product and if replacements don't work I am switching to kingston as I have seen people with this board having fewer problems with that manufacturer.
Article for reference http://gskill.us/forum/archive/index.php?t-4059.html
