Compatibility Question....
  • Compatibility Question....
    Hey,
    I just bought some new parts and was wondering if the ram and motherboard are compatible.
    CPU - Phenom II X4 965 Black Edition
    Motherboard - Asus M4N98TD EVO
    Ram - F3-12800CL9D-4GBRL
    Im new to this whole overclocking ram thing. Any help with this setup and I would be greatfull.
    Yep, no problems. Set memory frequency, timings, and voltage. If it is still a little unstable, set CPU-NB Voltage +0.1V and that should stablilize.
      Wow you guys reply fast thanks for the info.
