Need Help with F3-10666CL9D-4GBRL
  • Need Help with F3-10666CL9D-4GBRL
    Hi!!!
    I bought this mobo ASUS P5P43TD/USB3 and I have the opportunity to buy this memory (F3-10666CL9D-4GBRL) and I want to know if this memory is compatible and what is the best configuration for a good performance.
    Thanks a lot
    excuse me for my bad english
    Yes, the memory you have chosen is compatible and a good choice.
    MSI Big Bang xPower x58
    Intel i7 950
    GSkill DDR3 2000 6x2Gb
    Gigabyte GTX 460 x2 SLi
    OCZ Vertex 2 SSD - OS Drive
    Corsair TX950W
      Thanks, can you tell a good configuration for this memory?
        It should be plug and play. DDR3-1333 9-9-9-24
