I currently own the following Pc:
CPU: AMD Phenom II x6 1055T @ 4Ghz
CPU Cooler: Corsair H50 Hydro-cooling Kit
Motherboard: Gigabyte GA-MA790FXT-UD5P
RAM: 4GB-Kit G-Skill RipJaws 1600Mhz CL9 @ 8-8-8-24-1T
HDD: SSD Intel X25-M G2 Postville 80gb + WD Caviar Black 750gb
GPU: Sapphire HD5970 OC 2gb GDDR5 + Accelero Xtreme 5970 @ 850Mhz/1200Mhz
PSU: Corsair TX650 W
Sound Card: Auzentech Auzen X-Fi Bravura 7.1
The RAM is THIS one.
It says default voltage is 1.5v, my motherboard voltage gives it 1.6v as default, and I can lower the timings with that voltage to 8-8-8-24-1T
I am wondering, what is the max safe voltage for these RAM?
I would like to push the timings a little more, but it won't let me, and I wan't to ask what is max safe voltage before upping the voltage.
Would appreciate some help.
Thanks,
Kevin.
Thanks,
Kevin.
I tried both with no luck. Moving the voltage 1 notch gave me 1.65 volts. I don't know if this is good for it or not. I'd hate to roach my RAM.
