F3-12800CL9D-4GBNQ on MSI 870-G45 Motherboard
  • F3-12800CL9D-4GBNQ on MSI 870-G45 Motherboard
    I have been having some issues with my F3-12800CL9D-4GBNQ kit on my MSI 870-G45 motherboard. I am using an Athlon II X4 635 processor at stock settings.
    Motherboard: http://www.msi.com/index.php?func=pr...=&prod_no=2070
    I have the latest BIOS and all RAM settings are at Auto. Motherboard is running the RAM at 1333 9-9-9-24 at 1.5v.
    I get intermittent errors on with testing programs. Memtest86+ and HCI memtest will give errors with either one or both sticks installed on the motherboard. Sometimes it finds the error on the first or second pass. Sometimes it has to be running many hours before it shows up.
    Ran OCCT CPU test for 1 hour and that checked out OK.
    Is there a compatibility issue with this motherboard or is it RMA time?
    rogue,
    you shouldn't be getting any errors in Memtest or HCI test at stock default settings. if you have time you should test each stick individually to see if you have a bad one.
    or, you could just contact ask for an RMA.
    i've used at least six kits of that same memory for personal and customer builds and they have all been plug-n-play pretty much.
    Even though your particular motherboard isn't on GSkills "pre-qualified" list that seldom matters.
    MSI Big Bang xPower x58
    Intel i7 950
    GSkill DDR3 2000 6x2Gb
    Gigabyte GTX 460 x2 SLi
    OCZ Vertex 2 SSD - OS Drive
    Corsair TX950W
      I did test each stick individually, and both produce errors in both tests. This is what gives me pause. I guess it is possible that both sticks are bad but it just seems unlikely.
      This is 1600 RAM. At default, the motherboard runs it at 1333. But this shouldn't matter right? After all, you are pushing less than it is capable of.
        You're right, running the memory at a frequency lower than it is specified for shouldn't affect whether you can pass Memtest or not. It is rather strange though to have two bad sticks of GSkill memory.
        Is this a new build, or replacement memory for a build you already had?
        Intel i7 950
        Corsair TX950W
          New build. Everything seemed to be working fine until I decided to run memtest86+ and HCI memtest.
          Specs:
          AMD Athlon II X4 635 CPU
          MSI 870-G45 AM3 Motherboard
          G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (F3-12800CL9D-4GBNQ)
          GIGABYTE 1GB GeForce GTX 460
          SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM
          ASUS DRW-24B1ST SATA 24X DVD Burner
          OCZ ModXStream Pro OCZ600MXSP 600W ( +3.3V@25A, +5V@25A, +12V1@25A, +12V2@25A, -12V@0.3A, +5VSB@2.5A )
          OS: Windows 7 Ultimate 64-bit.
          I ran OCCT Power Supply and GPU test and everything seems OK. Never had Windows crash with a BSOD or anything like that.
            Rogue,
            Are you using the latest revision of Memtest 86+ (i think it is version 4.10 now)
            You could also try reseating your RAM.
            What slots are you memory modules installed in?
            Intel i7 950
            Corsair TX950W
              Yup. Latest revision.
              I have tried both RAM sticks together and each individually, so I don't think seating is an issue. Even if I had them improperly seated I have swapped them out often.
              When testing individually I have it in DIMM1. When using both together using DIMM1 and DIMM2. According to the manual these are the correct slots to use for dual channel mode.
                DDR3-1333 8-8-8-24 1.50V
                or
                DDR3-1600 9-9-9-24 1.50V and CPU-NB Voltage +0.1V
                Sounds like your CPU is struggling to operate DDR3-1600, so the CPU-NB boost should fix that.
