I have an EVGA E760 Classified motherboard and 6GB of GSkill Model F3-16000CL9T-6GBTD and I've been running this memory now for about a year at a little over spec speed of 2033MHz with an overclock of 4GHz on my Intel Core i7 920 without any problems until recently. Over the past month or so I've started getting a lot of random BSOD shut downs and I couldn't figure out what was causing the problem until I cut my memory speed down to 1600MHz. With my memory speed at 1600MHz I don't get any BSOD, but the minute I crack it back up to what I used to run it at I start getting BSOD either during Windows load or shortly after Windows loads. I haven't changed anything like BIOS update or anything else that would all of the sudden effect what I had stable and run for almost a year now. The only change I have made was upgrading from Windows Vista Ultimate 64-bit to Windows 7 Ultimate 64-bit. However, even before that recent change I was getting BSOD in Vista until I dropped the speed. This is very weird since I've run this memory for about a year without any problems. I did use MEMTest86+ to test the memory and that has very weird outcomes, as well. One run over 5+ hours showed no errors then another run at 3+ hours in showed all kinds of errors. Not sure what is going on, but like I said it's run like a champ for 11 months at spec until recently. I've always kept my memory at 1.65v with a CPU VTT Voltage at +200 it was the only way to even get it stable at 2033MHz with a 4.0GHz overclock. I ran this machine when I first overclocked it for 24+ hours in Prime95 and it passed without a hitch. I'm starting to think that my memory is dying, so any help here would be appreciated. I know you ask for a full BIOS setting deal when it comes to matters like this, however after 11 months of stable run I doubt it has anything to do with a BIOS setting. I do run a 1200 WATT Thermaltake ToughPower PSU so I'm doubting it is a power problem. I've also tried raising my voltages higher no effect. Doesn't matter what I do as soon as my memory is set to anything near 2000MHz auto fail.
I think my memory is dying
Bro that is way out of spec, I can see 1650 or so but 433+mhz is allot. Also running them at the max voltage what they are rated for does not help either, I would also have to say they are dying or your CPU and Motherboard may be biting the dust. Keep in mind the memory controller is on the CPU now, vs. the old FSB way of doing things! Over-clocking is fun but anytime you run something out of spec there is that risk of malfunctions.CPU I7-980X @ 3.81Ghz
MB ASUS P6X58D-E
GPU GTX480 @ 770Mhz
RAM 12Gb Patriot Viper Xtreme Division-2 DDR3 @ 1908Mhz
PSU Corsair AX 850W
SSD: Intel X25M 80Gb
HD 2x WD VelociRaptors 150Gb in Raid-0
Sager NP8662
CPU: Intel Q9100 @ 2.38 GHz
GPU: GTX 260M @ 612Mhz
RAM: G.Skill DDR3 1066Mhz 4Gb
SSD: Intel X25M 120Gb
Originally posted by Schwanke78 View PostBro that is way out of spec, I can see 1650 or so but 433+mhz is allot.
To the OP - due to the fact that we have to run fairly high QPI/DRAM (CPU/VTT) voltages in order to get this memory kit to DDR3 2000 speeds, it's possible that the on-die memory controller on the cpu is getting weak. I don't think it's the memory, but it could be.
I see that you've been running at +200mV CPU/VTT voltage since you started, do you happen to know what the actual CPU/VTT voltage is? I'm only guessing that default CPU/VTT is 1.10v? Does that sound right?
So if default CPU/VTT is 1.10v and we add .2 that puts your CPU/VTT at 1.3v - and if you've been running at DDR3 2000 for almost a year at that voltage you've been blessed, because most setups require quite a bit more than that. You might try a small bump in CPU/VTT up to 1.35v or so and see if that helps. Remember, this recommendation is based entirely on my best guess of what your BIOS default CPU/VTT voltage is.Last edited by wevsspot; 08-24-2010, 11:23 AM.MSI Big Bang xPower x58
Intel i7 950
GSkill DDR3 2000 6x2Gb
Gigabyte GTX 460 x2 SLi
OCZ Vertex 2 SSD - OS Drive
Corsair TX950W
Good catch man I didn’t even realize he was running the Trident's, so yeah he is only running a slight overclock very slight! I Should have caught this one, but I was thinking to myself damn 433+mhz over spec that's crazy!CPU I7-980X @ 3.81Ghz
MB ASUS P6X58D-E
GPU GTX480 @ 770Mhz
PSU Corsair AX 850W
Sager NP8662
gskill
Since you are having Memtest errors I'll bet that if you contact G.Skill RMA department they will authorize a return and replace your faulty memory modules for you. Especially considering that they are only 11 months old. No harm in asking.MSI Big Bang xPower x58
Intel i7 950
Corsair TX950W
wevsspot - thanks for the reply, but I don't think it's a matter of needing more voltage not after 11 months solid no fail performance. I'm seriously thinking the memory has started to fail at that speed after 11 months of use running at 2033MHz. Everything I've checked out even the BSOD logs points to memory failure and with the memory being so spotty during memtest86+ then it kind of makes it clear. I guess the only thing to do here is to test each stick one by one until I find the stick that is causing the failure.
Originally posted by wevsspot View PostSince you are having Memtest errors I'll bet that if you contact G.Skill RMA department they will authorize a return and replace your faulty memory modules for you. Especially considering that they are only 11 months old. No harm in asking.
Originally posted by Schwanke78 View PostBro that is way out of spec, I can see 1650 or so but 433+mhz is allot. Also running them at the max voltage what they are rated for does not help either, I would also have to say they are dying or your CPU and Motherboard may be biting the dust. Keep in mind the memory controller is on the CPU now, vs. the old FSB way of doing things! Over-clocking is fun but anytime you run something out of spec there is that risk of malfunctions.
Yeah I jumped the gun; thinking you was running 1600Mhz Ram @ 2033Mhz I was saying no way! Don?t know what to tell you man, what's you temps like on your CPU and Ram? 4.066GHz is pretty sweet been to 4.2Mhz myself but saw no point in running it 24/7 @ that speed or really any gain for that matter. Also 1.275v is pretty much in standard for a i7-920 or similar chips, I take it your running a 920 or 930. Personally I like to undervolt my stuff even my Sager Laptop is undervolted, just like to max the life out of my hardware. Anyways far as your hardware issues not sure what to tell you, something is starting to falter there?s no doubt about that.CPU I7-980X @ 3.81Ghz
MB ASUS P6X58D-E
GPU GTX480 @ 770Mhz
PSU Corsair AX 850W
Sager NP8662
Originally posted by zero08 View PostI guess the only thing to do here is to test each stick one by one until I find the stick that is causing the failure.MSI Big Bang xPower x58
Intel i7 950
Corsair TX950W
Originally posted by Schwanke78 View PostYeah I jumped the gun; thinking you was running 1600Mhz Ram @ 2033Mhz I was saying no way! Don?t know what to tell you man, what's you temps like on your CPU and Ram? 4.066GHz is pretty sweet been to 4.2Mhz myself but saw no point in running it 24/7 @ that speed or really any gain for that matter. Also 1.275v is pretty much in standard for a i7-920 or similar chips, I take it your running a 920 or 930. Personally I like to undervolt my stuff even my Sager Laptop is undervolted, just like to max the life out of my hardware. Anyways far as your hardware issues not sure what to tell you, something is starting to falter there?s no doubt about that.
Originally posted by wevsspot View PostI think that makes the most sense from a trouble shooting standpoint.
Yeah liquid works wonders my i7 build was the first time for water-cooling. Your CPU looks dead on but what about your RAM temps, I have a probe on mine since the Koolance RPK1000 gives you three and I run around 32c on load and that is without a RAM fan mind you. I know that some of the other brand RAM cooks at 2000Mhz, so I was just curious. I have also verified mine with a no-contact infrared thermometer. But as already said running one stick at a time should help narrow it down, but yes it?s a pain and probably three hours you don?t want to spend on doing it. Either way let us know how it goes and if you find a remedy.CPU I7-980X @ 3.81Ghz
MB ASUS P6X58D-E
GPU GTX480 @ 770Mhz
PSU Corsair AX 850W
Sager NP8662
Zero,
Even if only one stick is bad, GSkill will want the entire kit back to do a warranty exchange for you.
Maybe testing each of the three sticks individually will make you feel better knowing exactly which one or two are causing the problems - but like I said, they will still want the entire kit back.
And it really sucks that you have to buy a new kit just to keep you machine from being down. On the flip side, once your warranty replacement arrives you'll have a whole kit that you can sell to help offset the cost of the replacement kit you're buying.MSI Big Bang xPower x58
Intel i7 950
Corsair TX950W
Originally posted by Schwanke78 View PostYeah liquid works wonders my i7 build was the first time for water-cooling. Your CPU looks dead on but what about your RAM temps, I have a probe on mine since the Koolance RPK1000 gives you three and I run around 32c on load and that is without a RAM fan mind you. I know that some of the other brand RAM cooks at 2000Mhz, so I was just curious. I have also verified mine with a no-contact infrared thermometer. But as already said running one stick at a time should help narrow it down, but yes it’s a pain and probably three hours you don’t want to spend on doing it. Either way let us know how it goes and if you find a remedy.
