I have a problem with my Asus P7P55D Deluxe and Windows 7 64 bit. The BIOS version is the latest (1702).
I use two kits of the F3-12800CL7D 4GBRH (2Gx2), ie 8GB.
The XMP profile is detected correctly. I can let Memtest run without errors.
In between, I get BSOD with the message Error Management.
If I use only one kit everything works fine. Do I need to adjust the latency when using two kits?
