intermitent issue F3-10666CL9T-12GBRL & P6X58D-E
  • intermitent issue F3-10666CL9T-12GBRL & P6X58D-E
    Hi
    i just finished building a new system
    P6X58D-E (BIOS 0303),
    i7 980x,
    12GB (F3-10666CL9T-12GBRL) and
    windows 7 Pro 64bits.
    systems runs OK but every now and then when I restart the system, i get 8Gb instead of 12Gb. I restart again et voila, 12Gb is back.
    i am not into overclocking.. (at least not for now) just looking for a stable fast system. i ran all sort of memory tests and everything comes back clear. so I suspect it is a BIOS tweaking issue.
    i followed most of the threads on this topic and up-ed my QPI voltage from 1.2 to 1.25 but was wondering if anything is running a similar system and can suggest stock values to make it more stable. the P6X58D Premium is listed as a qualified MB, maybe G.Skill can share their settings ...
    thanks
    Sam
    Try enabling the XMP Profile. Do you have the latest BIOS for the motherboard?
      i am running the latest BIOS (0303).. but i am confused about XMP.. i thought these modules didn't support XMP profiles
      according the CPU-Z
      DIMM # 1
      SMBus address 0x50
      Memory type DDR3
      Module format UDIMM
      Manufacturer (ID) G.Skill (7F7F7F7FCD000000)
      Size 4096 MBytes
      Max bandwidth PC3-10700 (667 MHz)
      Part number F3-10666CL9-4GBRL
      Number of banks 8
      Nominal Voltage 1.50 Volts
      EPP no
      XMP no
      JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
      JEDEC #1 6.0-6-6-17-23 @ 457 MHz
      JEDEC #2 7.0-7-7-20-27 @ 533 MHz
      JEDEC #3 8.0-8-8-22-31 @ 609 MHz
      JEDEC #4 9.0-9-9-25-34 @ 685 MHz
      will try again in the BIOS...
        My mistake, I thought it was DDR3-1600.
        The memory should definitely be plug and play, so if you are having a problem, send them in for new replacements and the new kit should work fine.
          So are they supposed to run on stock values (everything on AUTO in the BIOS) ? i see too many post of tweaks./adjustments when dealing with 12Gb ... i would rather get advice from the PROs on what voltage/timing adjustments i should make,
          Once the system boots and picks up the 12gb, it is very sable, all the memory tests pass without a problem so far. to me, this is more of a BIOS not properly detecting the memory than a defective memory stick
          Sam
            What DRAM Voltage and QPI/VTT voltage are you running?
            MSI Big Bang xPower x58
            Intel i7 950
            GSkill DDR3 2000 6x2Gb
            Gigabyte GTX 460 x2 SLi
            OCZ Vertex 2 SSD - OS Drive
            Corsair TX950W
              right now, I have everthing set to Auto except QPI which I raised to 1.26 (default was 1.2)... DRAM voltage default on the ASUS board is 1.5
                Well.......
                If I were you I'd bump the QPI/VTT up to 1.30v
                If I were you I'd bump the DRAM Voltage up to 1.55
                If I were you take the CPU voltage off of auto and set it at 1.25v
                Before I threw in the towel
                Intel i7 950
                Corsair TX950W
                  Send them in for new replacements and the new set should work fine.
                    I keep seeing more and more users needing help with the issue of "missing memory", and more frequently the tech support folks telling users to send them in for replacements. I've also noted numerous threads around the web from users who have returned their sticks, received their replacements and everything is working fine now.
                    Can GSkill expound on what the problem is? I'm assuming that since the overwhelming recommendation lately has been to return the problematic memory, that GSkill has identified a mfg, engineering or quality issue......?
                    Intel i7 950
                    Corsair TX950W
                      The missing memory problem can be quite triicky as there are so many possible reasons. We simply ask people to send them back as an attempt to solve the problem. Then if the replacement has the same problem, the issue may lie elsewhere. We can not go through every possible reason for missing memory with each user, sometimes it may be user error as well, so that's why it is so difficult to troubleshoot.
                        gotcha.....
                        thanks for the response
                        Intel i7 950
                        Corsair TX950W
