Trident
  • Trident
    If all 3 of gskill memory chip is of exact same spec. Is Trident the best make IC (Integrated Circuit) one out of the three? Can gskill rep answer? I need some info/answer on this. Thanks.
    Which three are you looking at? Trident is one of our top series, so it will always have one of the best ICs.
      Just talking hypothetical but this is the closet I could find in comparison. Trident seem to have the best timing here, but maybe Pi is better? Hm not sure. But the Trident is your best chip in term of grade comparison sake right? Tx.
      Ripjaws
      http://www.gskill.com/products.php?index=236
      Pi
      http://www.newegg.ca/Product/Product...-352-_-Product
      Trident
      http://www.newegg.ca/Product/Product...-361-_-Product
        Yes, comparing these three, the Trident series would be the best. But, this particular PI is CL6, so it has a better spec than this CL7 Trident.
          Yea, sorry, I just edit Pi seem to have the better timing not Trident. But would you go for the Trident still? Both are very close in price and I don't mind paying extra $10 for either. Thxs.
            Hard choice, I would suggest picking the one you think looks/like better. Or if you want a memory cooler fan, just get the Trident.
              Last question, is it possible to lower the timing of the Trident to 6-8-6-20 from 7-7-7-21? since you say it's a better IC chip?
                No, only when compared to CL7 PI. This CL6 PI has better spec than the Trident, but the CL6 Trident has better spec than the CL6 PI.
                  Is it possible to overclock or underclock as the term maybe to 6-8-6-20 from 7-7-7-21 at lower frequency though? I still need that answer. I'm kind of new to the overclocking ram side. Thanks.
                    Yes of course, or with more voltage it should be capable.
