F3-12800cl9d-4gbnq & m4a785td-v evo
  • F3-12800cl9d-4gbnq & m4a785td-v evo
    CPU: Phenom II X3 720 @ 3.2GHz 1.325v(stock) Stable on prime95 and linx
    RAM: F3-12800CL9D-4GBNQ (2X2GB DDR3 1600 9-9-9-24-2T @ 1.5v)
    Motherboard: M4A785TD-V EVO (latest bios 2103)
    DDR3 1600 9-9-9-24-1T @ 1.5v
    CPU/NB @ 2000MHz 1.2v
    Memtest failed
    DDR3 1600 9-9-9-24-1T @ 1.55v
    memtest failed
    CPU/NB @ 2200MHz 1.3v
    memtest failed
    CPU/NB @ 2200MHz 1.35v
    memtest failed
    Can someone please help me get this stable at 1600MHz? Thanks.
    Try 2T. What slots do you have them installed in? I believe they should be in the two furthest away from the CPU.
      I can't set the command rate on this mobo. I currently have it in the slot closest to the cpu.
        Move them and that shouls solve the problem.
