Model of the motherboard: Gigabyte GA-890FXA-UD5 (revision 2.0)
Model of the memory: G.Skill F3-14400CL9D-4GBFLS (2x2GB) DDR3
Model of the CPU: AMD 1090t black edition
I just bought some g skill flare ram, I haven't received it yet. I'm under the impression I have to do some overclocking to get the ram to run at 1800mhz even though the ram is 1800mhz.
Is it safe to overclock it up to 1800?
Overclocking use to be dangerous in the old days but it seems it the only way to get your ram running faster them 1333.
I'm using my ram for gaming can anyone help me with configuring it for best performance?
