Hey all,
I am getting a LOT of BSOD issues running this RAM mobo combo. Mostly memory_management and PFN_LIST_CORRUPT and everything seems to be pointing to the RAM.
Here is my Setup:
CPU: AMD Phenom II X4 955
RAM: F310666CLL9D-4GBRL
Mobo: GA-890GPA-UD3H rev: 2.0
GPU: Radeon 5850
So I have downloaded and booted Memtest86. When run on only one stick of RAM at a time it runs fine 8+ loops with 0 errors. It doesn't matter which stick is run or the slot on the mobo that it is run on. When I run both the sticks together Memtest86 actually reboots my machine, as if I had pressed escape. Without warning, BAM: reboot.
Another weird thing is sometimes it will be completely fine for hours on end. Like yesterday, in the morning I had BSOD after BSOD, then I reset some of the voltages on my mobo and it was running fine for 12+ hours. Now tonight (first time I've had the computer on since last night), more BSODs.
My BIOS is the most current version for this board, I have the bare minimum drivers installed.
Currently I have:
TCL: 9
tRCD: 9
tRP: 9
tRAS: 24
Command Rate: 2
DRAM Voltage: 1.6v
NB Voltage: 1.40v
Please help.
Thanks.
Here is my Setup:
GPU: Radeon 5850
Currently I have:
TCL: 9
tRCD: 9
tRP: 9
tRAS: 24
Command Rate: 2
DRAM Voltage: 1.6v
NB Voltage: 1.40v
Please help.
Thanks.
