f312800cl9d-4gbnq issues with bsod's
  • f312800cl9d-4gbnq issues with bsod's
    Hello i am having cold boot issues with explorer not working and then random bsod's which mostly happen within the first 20 minutes of starting the pc but are now randomly happening at any time . The pc is a new build with windows 7 64 bit,motherboard is a gigabyte ga-p55a-ud3,cpu i5-750 and a hd5770 gpu.All of my bsod's are to do with memory error codes. I have installed the latest motherboard bios and gpu drivers and checked hard drive for errors.I ran memtest86 ver 3.4 for 12 hours and it showed no errors but the computer seems to work with the other memory from my gaming pc.Any advice would be greatly appreciated.
    Send the memory in for new replacements and the new set should work better. For memtesting, use 4.0V+ instead as ver 3.4 has limitations.
      rma
      i will send back to my supplier and let u know how i go with the replacement cheers
