Need memory/voltage settings for GSkill F3-16000CL9D on a Gigabyte GA-P55UD4P
  • Need memory/voltage settings for GSkill F3-16000CL9D on a Gigabyte GA-P55UD4P
    I can't seem to crack a stable setting running 8 gig at the stock 16000 Frequency. Also, I'm using a i7 875 processor. Anyone with any ideas?
    Enable XMP Profile and that will set the memory for you. One other thing you may need to adjust is the IMC Voltage. This is the memory controller voltage, and you'll want to find the lowest stable value.
