Model of the motherboard: GIGABYTE GA-MA785GT-UD3H Rev. 1.0
Model of the memory: F3-12800CL9D-4GBRL
Model of the CPU: AMD Athlon II X2 240 Regor 2.8GHz Socket AM3 65W
I have been having this issue for several months. For the first couple months, everything worked fine. Then I began to experience random reboots, which eventually became a constant loop where it would reboot right after the POST. I've tried inserting just one of the memory sticks, and it would boot, but would load windows, and then windows would automatically shut down, and go into the reboot loop again. I've occasionally gotten a windows blue screen with one stick of ram, but not every time. After adjusting the timings to 8-8-8-24, based on another forum post, both sticks ran fine for a couple days, but then started going back into the reboot loop pattern.
Thanks for your help!
