RAM Height - PI vs Trident, Turbulance FAN?
  • RAM Height - PI vs Trident, Turbulance FAN?
    Hi
    Is PI series having the same maximum height as Trident?
    can the Turbulance fan be use for PI series ram?
    No, I believe the Trident is 54mm while the PI is 55mm. The turbulance fan should work fine though.
